Two Finger Tip Tap suddenly giving right clicks , also while toggling the Force Touch Haptic Feedback , the feedback for 3 finger force touch is now different from four finger force touch
Thanks ! this worked . I did tinker with the settings . Now i have reset then in the same order ( not magnitude ) and things work , even the Haptic is working proper .
I still have this issue where , sometimes my three finger swipes first initiate a scroll in the active application and then trigger . Doesn't happen always ... but when it does happen once , it happens often thereafter .
