Using a two finger click on an icon in the dock widget brings up the contextual menu from the actual screen dock icon underneath (i.e. multifinger clicks are not blocked).
I would like the contextual menu on screen from the item on the dock widget but at the least the clicks should not be transmitted to the application the actual mouse pointer is over.
TouchBar/Trackpad
MacBook Pro (13-inch, Late 2016, Four Thunderbolt 3 Ports)
OS 10.14.5 (18F132)
BTT 3.168 (1341)
