enabling/disabling TrueTone from the TouchBar can sometimes cause a loop of enabling and disabling. Same thing as well with the Night Shift.
TrueTone is set as a button with the Long Hold set for a named trigger to toggle "Night Shift"
semi-fix: restarting BTT may fix it but not for long as it (de)activates TrueTone and Night Shift on its own and im forced to disable manually from "System Prefs" to stop the looping.
- Type of Mac: MBP 15' 2018
- macOS version: 10.13.6
- BetterTouchTool version: 2.645
