apologies for wide distribution, and for the basic question (pls refer me to appropriate support contact if applicable),
I've installed the trial version for one simple purpose: I have a new MacBook Pro with the dreaded keyboard, I'm using a BT Magic Keyboard as a workaround, but need something to disable the trackpad while I'm typing.
I thought the settings "Disable trackpad gestures after hitting a keyboard key", and "Reenable trackpad gestures only after touching center area".
It doesn't do either, however. I've tried typing and moving the trackpad right after, and it is not prevented.
Am I overlooking some configuration?
