Trash can for BTT
Would it be possible to have a trash can in BTT? I mean like in the Finder. What is deleted ends up there first and is only permanently deleted when the trash can is emptied.
I would find that convenient. :slightly_smiling_face:
Added in 5.075! Currently stuff in the trash will automatically be removed after 24h hours.
Yes, I noticed that :slightly_smiling_face: Thank you very much!
Mm, may I ask you to make that adjustable? Maybe 24 hours, a week and above all never.
yes I‘ll add some options for this :slight_smile:
Now available in 5.078 (uploading)
Wow, great addition!
This label should be removed or updated depending of the user configuration.
true :slight_smile:
