Clarification: At first I thought it was a bug, then I found out that you have to make a really big movement with your hand and it works, so it's not a bug, just a request for improvement
I used a pinch/spread trigger to send a hotkey.
I turned off in the system preferences what is set by default - the built-in functionality of opening the app launcher, but the shortcut I added does not work with a small pinch - I have to put my thumb right in the center of the trackpad, in the built-in functionality of the launcher view, a small pinch worked too.
I would appreciate it if you could make it react like the built-in functionality (or make it configurable)
MacBook Trackpad
- Type of Mac: MacBook M1 PRO
- macOS version: 12.5.1
- BetterTouchTool version: 3.839 (1986)
- Trackped: built-in original
Screenshot of the setting:
