trackpad_touch_duration to seperate doesn´t work
Can´t use these triggers at the same time. Nothing will happen.
But if I deactivate one, the other works.
I used "Actions Executed On Click PRESS DOWN" on both.
Any suggestions? Thanks
Sorry, found my mistake: Didn´t used "Aktionen beim LOSLASSEN des Klicks". With that it works :slight_smile:
But this doesnt work:
Nothing happens if both are active. If only one: trackpad duration doesn´t has any effect.
If I select "Trackpad Touch Duration is not ..." on one trigger, this trigger is used.
Now it somehow works.
The trackpad touch duration measures the time not during the time I do my forceclick. It measures the time before clicking, during the touchduration of the two fingers on the trackpad.
this implies one finger touch and even 4 finger touch ...
Would be nice to get a mesurement during the forceclick-time :slight_smile:
Maybe called trackpad_trigger_activation_time
