When a USB device is connected/disconnected (tried it with both a USB-C monitor and an external mic), BTT trackpad gestures stop working. Keyboard shortcuts and window snapping still work fine. A workaround that I found is to add and delete a trackpad gesture. That'll reactivate all the trackpad gestures until the next time a USB device is connected/disconnected. Note that the gestures still show as enabled in BTT settings, they just don't work when I try to use them. I just bought my Macbook today, so it's very unlikely that it's some kind of hardware issue/software conflict. I am also not getting any kind of notification about a usb device constantly disconnecting.
MacBook Trackpad
- Type of Mac: M1 Macbook Air
- macOS version: 11.2.3
3.561 (1701) - this is an alpha version, but it was also broken on the stable version (can't access the version number anymore)
