First, love this tool. I have been trying to figure out a way for a touch bar button that when pressed repeatedly or held will cycle a single application window through the four different quarter window snap locations, top left, top right, bottom right, bottom left (clockwise) until the window is in the desire quarter. Obviously I can't figure it out.
There is no automatic way to do this, however you could assign a little Apple Script like this and create 4 named triggers in the "other triggers" section in BTT.
set lastQuarter to get_number_variable "LastQuarter"
if lastQuarter is 0 then
set_number_variable "LastQuarter" to 1
trigger_named_async_without_response "moveToQuarter1"
else if lastQuarter is 1 then
set_number_variable "LastQuarter" to 2
trigger_named_async_without_response "moveToQuarter2"
else if lastQuarter is 2 then
set_number_variable "LastQuarter" to 3
trigger_named_async_without_response "moveToQuarter3"
else
set_number_variable "LastQuarter" to 0
trigger_named_async_without_response "moveToQuarter4"
end if
end tell
