Device: M4 pro Macbook Pro
OS: 15.1.1
Affected input device: MacBook Trackpad
Hi, I’m a new user of BetterTouchTool (BTT). Yesterday, I downloaded and tried out the software. I created two simple workflows, both of which send system hotkeys. These hotkeys are defined in Alfred to trigger some other software.
I used 2 fingers tiptap and 3 fingers tiptap gestures. At first, the 2 fingers tiptap gesture was very difficult to trigger, with a success rate of less than 40%. The 3 fingers tiptap worked a bit better, with about an 80% success rate. However, after a few hours, the 3 fingers gesture also became very difficult to trigger, and the 2 fingers gesture was almost impossible to trigger. Since it was late, I decided to leave it and went to bed.
This morning, I Googled the issue. First, I used the command tccutil reset All com.hegenberg.BetterTouchTool
to reset permissions, but it didn’t help. Today, BTT had an update, so I installed the new version, but the problem still persisted. Restarting the computer also didn’t solve it. I have recorded a video in Live View to demonstrate the issue and hope to get some help. I’ve already disabled the system's 3 finger drag feature, but it didn’t help. The software uses the default settings, any help? thanks!
