Tip Tab Problem
There seems to be an issue with "tip-tap - 2 Fingers Fixed" since BTT v.3.333.
I can trigger it correctly – but once I retrigger it without lifting the 2 fixed fingers I get the macro conflict menu with 2 times the same macro showing up
Mac 10.14.6
BTT 3.333
I can't reproduce this here, is maybe some other gesture being triggered that's defined twice?
Possible have a look at the live view to check.
This is odd...
Just had a look at live view. Same here. First time works second shows the menu.
Also tried to deactivate it to make sure there are not 2 macros with same trigger. But after deactivating this macro, no macro gets triggered for this gesture.
