I set three finger Tip Tap to close the current tab (i.e. ctrl + w). The action works fine on the built-in trackpad on my Macbook Pro. But on my Magic Trackpad, the same gesture is very hard to trigger the action. I have to try several times to trigger it.
- Type of Mac: MacBook Pro (15-inch, 2018)
- macOS version: 10.15.5
- BetterTouchTool version: 3.372
