SystemDoNotDisturbState is undefined in macOS Big Sur
	return get_string_variable "SystemDoNotDisturbState"
end tell
What I got:
missing value
Expected:
"1"
Thanks for reporting, I’ll look into that!
Will be fixed with the next update, however this is a number variable so you need to use
	return get_number_variable "SystemDoNotDisturbState"
end tell
this method always return 0 in Big Sur
