Swiping between spaces choppy, reversed
Trying out BetterTouchTool to maybe replace other mice drivers like BetterMouse, MacMouseFix and Logi Options+. It's certainly overkill just for that, but I may grow into it.
However, after downloading the Logi MX preset and playing with it for 20 minutes, I still can't it getting working properly. When holding down the thumb button and dragging to switch between spaces, the direction is reversed with seemingly no way of changing it. It also gets stuck at the end until I let go, completely ruining the experience.
Any idea if direction can be configured and what makes spaces get stuck ~80% into the transition before button release?
Which macOS and BTT version are you running?
I just checked again but the space switch is working fine here. Dragging right goes to the right space, dragging left to the left space. Example config:
Hi, latest BTT, latest Sequoia. I want to drag left to move to the space to the right, as if I'm grabbing the contents and dragging it. Same as on the trackpad.
In that case you'd need to set this value to negative (for both directions), this will inverse it:
Could you briefly describe your Mac's display setup? I think I might have an idea that could explain your 80% issue, it might be related to displays.
Thank you! Will try that.
Internal MacBook Air 13" to the right, main Dell U4025QW in front of me
That would confirm my suspicion. I'll do a little change for the next build that might help in your case (in about 30min)
I think v6.516 should resolve the issue you have encountered (uploading now)
Wow looks like you completely fixed it. Curious what the issue and fix was? Thank you!
just a bug in the offset calculation that happened on some display setups
