Submenu from Float Menu not working
Note:
When I try to create a submenu in float menu, it works in a first time, but, when I restart the bettertouchtools, it not working anymore.
When I click in the submenu button, nothing happened.
Affected input device (e.g. MacBook Trackpad, Magic Mouse/Trackpad, Touch Bar, etc.): Macbook Floating Menu
  • Type of Mac: MacBook Air M4
  • macOS version: 15.6
  • BetterTouchTool version: 5.468
Can you provide the submenu config? What should this button do?
Hello.
What configuration do you need? Is it possible to export?
The button just open a submenu.
When I enable and disable the "Script Enabled" option, the Submenu works again until I restart the Bettertouchtool.
I have a fresh installation without any script.
I have the same problem , except it does not re-enable when I tick the script option.
Ah, sorry. I got your issue now. I can also confirm the same issue and that the same workaround with enable/disable the "script enabled" checkbox. I'm on version 5.554 (2025081304).
BTW you can export any trigger using any of these 2 options:
The "Copy" one will copy to your clipboard the item configuration, so you can paste it whenever needed.
Sorry one recent optimization was too aggressive. Should be resolved in 5.556!
