Stream Deck - Switch profiles/pages
Are you sure this is not just the profile you created and sent to me? (For me such a profile does not appear)
I'll make the notes field available soon. Alternatively you can use BTT's "comment" action for such cases
YES!!!! :rofl: :rofl: :rofl: :rofl:
Sorry man, I didn't remember that... :sweat_smile:
Great, thanks!
I've been using BTT profiles for a few days now and everything works perfectly. But now I've noticed that the option to go to the previous profile doesn't work. When I trigger this action, it always goes back to the BTT-01 profile instead of going to the previous BTT profile.
Sorry, what I wrote before is not correct.
I have been doing more tests and I have found that the action of going to the previous profile always goes to the profile with which the stream deck editor was opened.
Steps to replicate this issue:
  • go to the BTT-05 profile
  • close the stream deck editor
  • re-open it
  • switch between different profiles by moving away from BTT-05
  • trigger the "switch to previous profile" action always switches to the BTT-05 profile
This behavior happens even if the profile is not one of the preconfigured ones by BTT:
  • go to the "Default" profile (created with the stream deck editor)
  • re-open it
  • switch between different profiles by moving away from the "Default" profile
  • every time the "switch to previous profile" action is triggered it always leads to the "Default" profile
Sorry again, there is another issue that I found due to the action of "switch to previous profile".
Following the previous example, if BTT has "saved" the "BTT-05" profile as the previous profile, every time the stream deck is opened it does not open with the last profile used, but with the "BTT-05" profile.
Same if BTT has "saved" the "Default" profile as the previous profile. Every time the stream deck is opened it does not open with the last profile used, but with the "Default" profile.
EDIT: This issue is fixed temporarely if stream deck is closed and BTT is quitted. Then, restarting both apps, makes that stream deck restarts always with its last active profile. The issue occurs again in a permanent way if the "switch to previous profile" is triggered.
Hi @Andreas_Hegenberg
There is an issue with the "Switch to the previous profile". I have tried to explain it in the last 3 messages.
I just wanted to let you know in case you hadn't seen these last messages.
Unfortunately this most likely can not be solved with the current Stream Deck API, I'll hide the "Switch to previous profile" option. BTT doesn't have control over this behavior and the Stream Deck API docs are inconsistent here.
:ok_hand:
Just a reminder that the "Switch to previous profile" option is still available in the dropdown. You should hide/remove it, as you said, becasue it can't work as expected.
Also, you could add the note field to the action, as suggested here:
@Andreas_Hegenberg
It would be possible to have an action to get the name of the active profile and the number of the active page of the BTT profiles?
That would be very very useful for me!
PS: By the way, the "Switch to previous profile" option is still available in the dropdown menu. Do you have this issue in the to-do-list?
