Hello:
For people who is already using BTT with Stream Deck:
do you know any action to refresh a widget button? I have one who runs a bash script to display my ip. I wanna click that button to refresh the value.
it's possible to update a button label from another action?
you can assign the run apple script action as an action, the return value of that will also update the label.
Alternatively use the „refresh_widget“ function: Using Apple Script or JXA · GitBook
There is a new update_stream_deck_widget function to update arbitrary Stream Deck buttons, I’ll update the documentation tomorrow with some examples
