Stream Deck + Dials not executing macros while in plugin mode
Hi I'm using latest version of BTT with Stream Deck + in plugin mode, but getting no response. I started with simply trying to assign Dial 1 Click to a keystroke, but to no avail.
In plugin mode, you have to add the BetterTouchTool action to the button/dial explicitly. Does plugin mode not work with the dials? If plugin mode should work with the dials, since there is no way to assign fixed identifier numbers to Stream Deck dials in BTT, is there another way I can tell the BTT action in SD what it's supposed to be triggering in BTT?
