Strange behavior in Scrivener
Just a note: For Scrivener, the "Menu bar" action must always be set up twice for it to work. It took me a while to figure this out. Maybe this is also the case with other apps. Or it is a bug in Scrivener :man_shrugging:
It might be that Scrivener "lazy loads" its menu items. In that case the first action will trigger it to load but they won't be available to BTT immediately. Then with the second one they are available and BTT is able to trigger them.
I'll look into this, maybe I can add some code that auto-retries 2 or 3 times if the first one didn't work.
