When updating a floating menu item’s background color using BTTMenuItemBackgroundColor
, the color string is specified as four comma-separated values (e.g. '0,0,20,255'
). Here, the alpha component is expected to be an integer between 0
and 255
. However, many developers and APIs follow the standard convention of a normalized alpha value between 0
and 1
. I propose that BTT be updated so that the alpha value conforms to this standard, allowing users to specify the alpha component as a float between 0
and 1
. This change would align BTT with common practices, reduce the need for manual conversions, and minimize potential confusion.
Question, how could this be implemented and not cause backward compatibility issues?
- Device: MacBook Pro (14-inch, 2021)
- macOS: 15.3 (24D60)
- BTT Version: 5.168 (2025020212)
- Alpha: 0 update(s) behind latest Alpha version 5.168 (2025020212).
- Regular: Installed version is ahead of latest Regular version 5.140.
I came across this bug when developing the Color Picker widget.
