Please remove. I just needed to restart the magic trackpad to solve a random bug.
Please download the preset to see what i'm talking about. Basically, because of the update, my magic trackpad has 3 pressure levels instead of the normal click + force click
So I actually just downloaded older versions and the same problem is happening. Do you think it has something to do with Mojave? But I only got the problem after the update. Maybe it changed a setting? Please help fix.
All solved. Just needed to restart trackpad. Can delete/resolve.
