<SOLVED> BetterTouchTool not opening, does nothing
I just purchased BetterTouchTool but when I double click on the app, nothing shows up, just nothing happens. Anyone encountered this?
I am on Macbook Air early 2014 macos Catalina 10.15.4.
Hey,
try to reset all BTT permissions using this terminal command:
tccutil reset All com.hegenberg.BetterTouchTool
This usually fixes system permission issues that could prevent BTT from launching.
Wow that actually worked! Thanks!
