So I've been using BetterTouchTool to provide custom snap areas for a while, and it's been fine. I've now switched to a pair of Samsung CH580 monitors attached to my MacBook Pro's two thunderbolt ports.
The problem I'm getting with this new pair of monitors is that
(1) snap zones I've defined on one monitor also appears on the other;
(2) When I drag into a snap zone, the new window size is correctly shown on the monitor... but then it goes and snaps to the correct size on the other monitor
So it seems to be getting confused as to which monitor is which - but ONLY with this pair of monitors. It works fine with the Dell monitors I use at the office and on the MacBook's own display.
One difference is that the Dell monitors in the office are on the right of the MacBook and at home the Samsung monitors (with the problem) are on the left.
I've tried clearing all snap areas and creating from scratch but no difference.
MacBook Pro. Doesn't make any difference which pointing device I use.
- Type of Mac: MacBook Pro
- macOS version: High Sierra 10.13.6
- BetterTouchTool version: 2.660 (968)
