I just updated to the latest version today stating that now it will allow to use the classic snapping - thus removing that ugly "border" macOS added.
However, it does not appear to work (restarted BTT as well)
I still see the border after changing the settings.
Am I doing something wrong?
if you use BTT's classic snapping, make sure to disable the system tiling in System Settings Desktop & Dock
OK!
I found another setting there that actually allows you to remove the margin - so I just used that (since I do not use any other tiling than what the OS now supports, that is, 4 tiles in total, it is fine)
Perhaps I missed it, but this could deserve a small note in the relevant BTT setting?
