"Snap to top left" width 50% height 100%
Hello.
I'm enjoying this app very much.
Currently "Snap to top left" has width 50% height 50%
I need to get it width 50% height 100%
Same setting for "Snap to top right"
Is this possible without needing to create custom new snap area?
Thank you.
I don't understand what you are trying to achieve. If you don't need quarters, you can disable them:
When I drag a window to left or right corner it resizes to 50% width and 50% height.
This is the default behaviour.
I need the window to become 50% of the width of the screen and 100% of the height of the screen minus the menu bar.
I do not know how I can explain this differently.
I cannot upload images to show you.
I just noticed that I do not have the same preference window as you. I'm on Ventura.
Need to find advanced options
OK I get it now. All good.
I though that disabling a corner disable the snapping action.
