[Snap Areas]: Menu entry: GONE...
I am unable to see the SNAP areas when I drag a window.
I am unable to also see the snap area menu entries in the pull down menu. I have all of the other entries for:
  • Preferences
  • Version
  • Check for Alpha Version Updates
  • Documentation
  • Release notes
  • Community feedback
    etc
HOWEVER THE EDIT SNAP AREAS IS MISSING, as well as the CREATE NEW SNAP AREA.
I checked that I have both Window Snapping enabled.
IMPORTANT: I do not believe it has anything to do with the OS I am using, as I have another machine and it is working fine on it and they are setup identifcally.
Macbook Pro
Screenshot_BTT_NoSnapAreas_1
  • Type of Mac: MacBook Pro
  • macOS version: Mojave
  • BetterTouchTool version: 2.641
I confirm I have the latest version, and rebooted several times.
In the second screenshot, on the bottom, uncheck the "disable snap area" checkbox :wink:
OMG!!!!! MAJOR DOH!!!!!
Thank you lots. I was confounded by this and was sure I had something wrong on my side as it did not make sense for the menu entry to be gone without some intentional code command.
Honestly I recently ran into this myself :grinning:
Im future versions disabling the feature won't hide the menu item anymore.
