Hi!
I've been using BetterTouchTool for a while now. Recently, I noticed that all of my snap areas have disappeared. Furthermore, there is no longer an option to "Edit Snap Areas" in the BTT menu bar icon. All traces of Snap Areas seem to be completely gone. I still have window snapping enabled.
The way I set up Snap areas is by having them show up while I hold down fn + ctrl, which will also move my window around. Now, whenever I try to activate my snap areas, they do not appear.
Any help would be great since these are essential to my daily workflow.
