Small UI Glitch
There is a small gitch that for some triggers, the action panel shows as empty even though actions are assigned to it. In the screencast you can see I have a ^→W which has a "Cycle through multiple actions" assigned but when I click on the trigger after clicking to deselect all triggers the action doesn't show, but if I click to another trigger and THEN click the ^→W then the action is shown. Nothing major.
Affected input device (e.g. MacBook Trackpad, Magic Mouse/Trackpad, Touch Bar, etc.): Settings GUI
  • Type of Mac: macBook Air M2
  • macOS version: 14.5
  • BetterTouchTool version: 4.605
