When using the small step adjustments (volume, brightness) only with trigger keys, randomly does not work. I'm using cntrl as the trigger.
Macbook
Macbook
- Type of Mac: MacBook Pro 2020
- macOS version: Catalina 10.15.5
- BetterTouchTool version: 3.383 (alpha)
Sometimes works, sometimes doesn't. Can't figure out exactly when
unfortunately this is something that can not be fixed for these actions, they work by simulating option+shift+brightness/volume (which is the standard shortcut for small step increments).
If another modifier is added these standard shortcuts don't work anymore ;-(
It would probably be possible to write a little Apple Script that does the brightness / volume modifications as BTT can also do it without simulating buttons, however I'm not sure whether that would be worth it. It also wouldn't show the volume/brightness overlay when doing that.
Hi, thanks for the reply @Andreas_Hegenberg. You say they simulate the built in shortcut for adjusting. That makes sense. So, would finding a way to disable the original shortcuts help? This could be done in Karabiner possibly.
If they are disabled, the system probably also won't react to the BTT simulated ones anymore ;-(
I see. Well you for the reply. I'll play around and post if I get any results.
