single quotes do not paste correctly
code compliant single quotes are pasted as some other type of single quote more commonly used in non coding text editors
Touch bar button that pastes text
- Type of Mac: High Sierra
- macOS version: 10.3.6
- BetterTouchTool version: 2.6.41
workaround: i had to copy a single quote and paste it into the settings box
