"Show Control Center" not working
The action "Show Control Center" is not working.
I have tried trigger it with shortcut and buttons inside floating menus.
macbook pro 16 m1 max
ventura 13.6
BTT 4,272
Mh it seems to work ok here.
BTT uses this apple script to show the control center on 13.6:
tell application "System Events" to click menu bar item 2 of menu bar 1 of application process "Control Center"
Could you check whether that works in the Apple Script Editor on your machine?
it doesn't work in my laptop.
Applescript returns error number -1728 from application process* "Control Center": System Events" can't get application process "Control Center"
it works if I delete the space between Control and Center:
tell application "System Events" to click menu bar item 2 of menu bar 1 of application process "ControlCenter"
interesting, this has changed multiple times during the different macOS versions. I’ll change it to just try both :grinning:
