I have defined shortcuts to [open/bring to the front] my most used applications.
I have following config.
is actually triggered by CAPSLOCK + S, because I remapped capslock to this key.
It is defined in karabiner elements:
And it worked very well for few months and helped me a lot. But now I started to experience problems with this.
I am switching for example from app1 => app2 => app3 => app2 => app1 using shortcuts and after this chain I can't use any other BTT shortcuts.
I can make BTT working again by:
- restarting BTT or
- clicking by mouse on any app icon on OSX dock.
- using alt + tab
Is there any log or another way to debug this?
I tried to reproduce this, but seem to be unable to do so.
Are the non-working shortcuts defined globally or per app?
Which version of BTT are you running?
Thanks for your fast reaction
globally or per app? Globally
version of BTT: 2.801
Weird, is this always reproducable?
Could you go to the about screen in BTT and click "Export Debug Information"? This will create a folder called BetterTouchToolDebug that you can send to andreas@folivora.ai, then I can have a closer look.
Just sent you email with debug information.
It happens all the time.
Ah I think it's related to secure input in iTerm. Could you confirm that disabling secure input fixes it?
I'll check why this is happening and add a workaround.
Yeah, it was it. Thanks a lot for your fast reaction again
