I wanted to assign a shortcut to a snap area. As shown here
But my settings look different. Is this feature in a different location?
Found it, thanks!
Can I assign a shortcut to the built-in/default snap areas? (the corners, top/down).
Workaround would be to create custom snap areas to "replace" the built-in ones, but I would prefer using the existing ones with shortcuts
Ah, missed that. Perfect, thanks
Me again (newbie)...
I'm using the action "Frontmost Windows in Quarters" in a shortcut. I have 2 monitors and I want to do this only on the monitor where the cursor is. Currently all Windows on all monitors are snapped to the corners.
