Since I upgraded my rigs to macOS 10.13.6 the shortcuts I heavily rely on combining modifier keys with the normal mouse's scroll wheel horizontally and vertically are messed up.
As soon as I hold SHIFT down and scroll vertically it is turned into scrolling horizontally. BetterTouchTools fires all kinds of shortcuts I programmed to horizontally scrolling although I am actually SHIFT+vertically scrolling.
This is hitting my personal workflow very hard since I rely on using the scroll wheel with both axes and all combinations of modifier keys to edit audio inside AVID Pro Tools.
Normal Mouse, it's a Logitech Performance MX used without a special driver or app
- Type of Mac: MacBook Pro 12.1, Mac Mini 6.1, Mac Pro 5.1
- macOS version: all on 10.13.6
- BetterTouchTool version: all on 3.401, but I also tried a couple of earlier versions
