I have the UK magic keyboard with numeric keypad. So, I want to change "" key to left shift. When I set up this shortcut and press the "
" BTT beings trigger the holding the shift key indefinitely... And while writing this I've just noticed that it's not the "`" key only. Basically shift down doesn't let up, no matter what key it's assigned to.
- Mac Mini M1 2020
- macOS version: 13.0.1 (22A400)
- BetterTouchTool version: 3.952
Also, just confirmed this happens on my MacBook as well.
