Disabling both Show Menubar Icon and Show Dock Icon (in standard settings > user interface) makes the settings window inaccessible (as in it doesn't open at all). BTT continues to work, gestures etc. are fine and BTT is running in activity monitor, but no settings of any kind can be changed, including fixing this silly mistake.
Both app and system restarts were tested. To fix it I had to uninstall BTT entirely (including settings) and reinstall fresh.
Happened on Macbook Pro, all inputs (gestures, keybinds etc) work fine, but the settings window is either unable to be opened or is opened hidden.
Exact settings:
Both unchecked = no visible settings panel.
- Type of Mac: Macbook Pro
- macOS version: 10.15.7
- BetterTouchTool version: 3.540
Perhaps a warning of what will happen if both are disabled, or a toggle between the two to avoid the problem entirely would help?
