I have a Loupedeck Live which I'd like to use with the original software, not with BTT. (I use BTT for a lot of other things and love it :)).
Now for a few weeks, I've noticed the following: if the original Loupedeck software is started before BTT, everything works as expected. But if the device is unplugged and replugged in, sometimes (and more often in recent weeks) BTT is quicker in grabbing the USB serial connection to the device and Loupedeck can't connect to it because the device is already blocked by BTT (or at least it doesn't answer the HTTP-over-USBModem handshake).
This happens, even if no action has been configured to trigger on LoupeDeck. It would be fantastic if there were a way to disable this functionality in the Settings or so. Right now, I need to quit BTT and restart it whenever this happens ... which is a bit annoying ![]()
Thank you very much in advance for looking into this!
Loupedeck
- Type of Mac: MBP 16"
- macOS version: 26.6.2 (25G83)
- BetterTouchTool version: 6.828
**Additional information (e.g. crash logs, related issues, etc.):
This is what LogiPluginService (for Loupedeck) outputs in this case, if started with debugging enabled:
2026-09-18T15-24-29-465 | 28 | INFO | IsUsbConnection: True
2026-09-18T15-24-29-465 | 28 | INFO | IsBluetoothConnection: False
2026-09-18T15-24-29-465 | 28 | INFO | Connecting to device '/dev/cu.usbmodem2101_PID_4&VID_2EC2'
2026-09-18T15-24-29-465 | 28 | INFO | (/dev/cu.usbmodem2101) Connecting
2026-09-18T15-24-29-466 | 28 | INFO | (/dev/cu.usbmodem2101) Sending BREAK signal
2026-09-18T15-24-29-491 | 151 | VERB | MIDI lock check
2026-09-18T15-24-29-493 | 151 | VERB | Serial devices found: 2
2026-09-18T15-24-30-479 | 28 | INFO | (/dev/cu.usbmodem2101) Sending handshake
2026-09-18T15-24-30-480 | 28 | VERB | (/dev/cu.usbmodem2101) Serial message sent (114): (114) 47-45-54-20-2F-69-6E-64-65-78-2E-68-74-6D-6C-20 ...
2026-09-18T15-24-32-982 | 28 | WARN | (/dev/cu.usbmodem2101) Did not receive handshake response
2026-09-18T15-24-32-982 | 28 | INFO | (/dev/cu.usbmodem2101) Closing
2026-09-18T15-24-32-983 | 28 | INFO | (/dev/cu.usbmodem2101) Sending BREAK signal
2026-09-18T15-24-33-998 | 28 | INFO | (/dev/cu.usbmodem2101) Closed
2026-09-18T15-24-33-999 | 28 | WARN | Device not connected**
Only happens, when BTT keeps the device open:**
ingorammer@IngosMBP ~ % sudo lsof | grep -i usbmodem
BetterTou 47080 ingorammer 10u CHR 9,5 0t432 1223 /dev/cu.usbmodem11232301
