I'm using external monitor with keyboard and magic trackpad 2 at home.
Palm rejection or force touch pressure of touchpad can be used differently when I use internal and external trackpad.
It would be great if I can choose separately.
you could do it by exporting the two presetand importing the one you want to use. make sure you get the settings with triggers . you could have a 3rd preset with hotkeys/triiggers to help this process. you would have to delete as well because when it load s it just saves another version of the preset.
Same issue. I'm surprised this does not get more love. The solution seems pretty cumbersome.
We really need device profiles with advanced settings. I saw he was looking into something similar for a user with twin trackpads.
I submitted a feature request, please comment and vote!
I just came here to request this. This would be a great feature to have.
