There are many issues with the scripting TextView. I believe it is not editing in UTF-8 mode.
As quite and double quotes are being replace with look alike but not right encoding counterparts.
However this bug ticket for this interesting case. This code runs fine in Visual Code or command prompt. end goal is along side cryptos current value I am putting the % of 24 hours
#!/opt/homebrew/bin/python3
import os
import json
from pycoingecko import CoinGeckoAPI
coin = os.getenv('COIN')
#coin = 'ethereum'
fiat = os.getenv('FIAT')
#fiat = 'usd'
cg = CoinGeckoAPI()
jsonData = cg.get_price(ids=coin, vs_currencies=fiat)
jsonDump = json.dumps(jsonData)
obj = json.loads(jsonDump)
output = obj[coin][fiat]
op = "{:.2f}".format(output)
#1
print('${0} ( -2.99%)'.format(op))
# above line should print the result but it makes the touch button disappear.
#2
print('${0}'.format(op))
# this line print the value just fine.
Affected input device Touch Bar
Not sure how to take screenshot of touch bar.
- Type of Mac: Apple Silicon M1
- macOS version: 12.2.1
- BetterTouchTool version: 3.756
There is no workaround that I have found if anyone have any please do let me know.
