Running Custom Apple Script Keyboard Illumination Up & Down creates a slider in the Touch Bar that affects the volume up/down instead.
- Type of Mac: M1 2020
- macOS version: 11.6
- BetterTouchTool version: 3.579
I might not understand, but this depends on the script you run in the custom sider. Can you post your setup?
most likely the first action (the script) contains code to change the volume. I’ll post a script that can change the keyboard illumination later when I‘m back at my computer
Awesome, thank you!
Hey, were you able to write a script?
