Whenever I try to access the save/restore window layout action, the app crashes and restarts. I am using the latest version (3.553) and have restarted my machine twice.
- Type of Mac: Macbook Pro 13" 2019, Four Thunderbolt 3 ports
- macOS version: Big Sur 11.1
- BetterTouchTool version: 3.553
See below for the diagnostic console report:
Date/Time: 2021-02-03 10:17:57.448 -0600
End time: 2021-02-03 10:19:56.948 -0600
OS Version: macOS 11.1 (Build 20C69)
Architecture: x86_64h
Report Version: 32
Incident Identifier: 1F4285E9-D0BA-4F69-B4C9-1CDECFD13D49
Data Source: Microstackshots
Shared Cache: 467A83CB-BA86-3F07-B652-B9256C74080A slid base address 0x7fff2006b000, slide 0x6b000
Command: BetterTouchToolAppleScriptRunner2
Path: /Users/USER/*/BetterTouchTool.app/Contents/XPCServices/BetterTouchToolAppleScriptRunner2.xpc/Contents/MacOS/BetterTouchToolAppleScriptRunner2
Identifier: com.hegenberg.BetterTouchToolAppleScriptRunner2
Version: 1.0 (1)
Parent: UNKNOWN [1]
PID: 8854
Event: wakeups
Action taken: none
Wakeups: 45001 wakeups over the last 120 seconds (377 wakeups per second average), exceeding limit of 150 wakeups per second over 300 seconds
Wakeups limit: 45000
Limit duration: 300s
Wakeups caused: 45001
Wakeups duration: 120s
Duration: 119.50s
Duration Sampled: 0.00s
Steps: 1
Hardware model: MacBookPro15,2
Active cpus: 8
Boot args: chunklist-security-epoch=0 -chunklist-no-rev2-dev
Fan speed: 4107 rpm
Heaviest stack for the target process:
1 start + 1 (libdyld.dylib + 87585) [0x7fff20396621]
1 main + 94 (BetterTouchToolAppleScriptRunner2 + 7585) [0x10b6abda1]
1 -[NSXPCListener resume] + 262 (Foundation + 529085) [0x7fff212202bd]
1 xpc_main + 437 (libxpc.dylib + 85605) [0x7fff200c7e65]
1 _xpc_objc_main + 825 (libxpc.dylib + 87005) [0x7fff200c83dd]
1 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 975748) [0x7fff2128d384]
1 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 212 (Foundation + 393121) [0x7fff211fefa1]
1 CFRunLoopRunSpecific + 563 (CoreFoundation + 521934) [0x7fff204716ce]
1 __CFRunLoopRun + 2731 (CoreFoundation + 526418) [0x7fff20472852]
1 __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9 (CoreFoundation + 780656) [0x7fff204b0970]
1 _dispatch_main_queue_callback_4CF + 940 (libdispatch.dylib + 64390) [0x7fff201dcb86]
1 _dispatch_client_callout + 8 (libdispatch.dylib + 14279) [0x7fff201d07c7]
1 _dispatch_async_and_wait_invoke + 87 (libdispatch.dylib + 67268) [0x7fff201dd6c4]
1 __105-[BetterTouchToolAppleScriptRunner runAppleScript:timeout:useJavaScript:presetPath:foreground:withReply:]_block_invoke.88 + 258 (BetterTouchToolAppleScriptRunner2 + 12094) [0x10b6acf3e]
1 -[OSAScript executeAndReturnDisplayValue:error:] + 222 (OSAKit + 98210) [0x7fff6f780fa2]
1 OSAExecute + 52 (OpenScripting + 77188) [0x7fff36442d84]
1 AppleScriptComponent + 1676 (AppleScript + 20188) [0x7fff702fdedc]
1 ASExecute(unsigned int, unsigned int, int, unsigned int*) + 500 (AppleScript + 35782) [0x7fff70301bc6]
1 UASExecute(unsigned char) + 185 (AppleScript + 230415) [0x7fff7033140f]
1 UASExecute1() + 288 (AppleScript + 230770) [0x7fff70331572]
1 UASValue_Send(unsigned char, unsigned char, TUASClassIndex, unsigned char) + 326 (AppleScript + 397060) [0x7fff70359f04]
1 UASActor_Send(unsigned char, unsigned char, unsigned char) + 379 (AppleScript + 186560) [0x7fff703268c0]
1 UASRemoteSend(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char*) + 507 (AppleScript + 349668) [0x7fff7034e5e4]
1 TUASApplication::Send(TStackFrame_UASRemoteSend*, AEDesc*, AEDesc*, unsigned char, unsigned char, unsigned char) + 1591 (AppleScript + 213453) [0x7fff7032d1cd]
1 ComponentSend(AEDesc const*, AEDesc*, int, int) + 485 (AppleScript + 141634) [0x7fff7031b942]
1 aeSend + 355 (AE + 163912) [0x7fff26268048]
1 AESendMessage + 3045 (AE + 116982) [0x7fff2625c8f6]
1 ??? (AE + 52953) [0x7fff2624ced9]
1 AEVTsysoexec + 2564 (StandardAdditions + 106711) [0x10dd6e0d7]
1 CheckEventQueueForUserCancel + 21 (HIToolbox + 643488) [0x7fff287621a0]
1 PullEventsFromWindowServerOnConnection(unsigned int, unsigned char, __CFMachPortBoost*) + 45 (HIToolbox + 255899) [0x7fff2870379b]
1 SLEventCreateNextEvent + 9 (SkyLight + 1051881) [0x7fff24ceece9]
1 SLSGetNextEventRecordInternal + 278 (SkyLight + 2793182) [0x7fff24e97ede]
1 CGSSnarfAndDispatchDatagrams + 169 (SkyLight + 40694) [0x7fff24bf7ef6]
1 mach_msg_trap + 10 (libsystem_kernel.dylib + 3710) [0x7fff20346e7e]
Powerstats for: BetterTouchToolAppleScriptRunner2 ($(PRODUCT_NAME)) [8854] [unique pid 108302]
UUID: D6C6B032-ACD6-357A-B4A2-354BFB7A7939
App Version: 1.0
Build Version: 1
Parent: UNKNOWN [1]
UID: 501
Sudden Term: Tracked (allows idle exit)
Footprint: 6536 KB
Start time: 2021-02-03 10:19:56.276 -0600
End time: 2021-02-03 10:19:56.276 -0600
Num samples: 1 (100%)
Primary state: 1 samples Non-Frontmost App, Non-Suppressed, Kernel mode, Effective Thread QoS User Initiated, Requested Thread QoS User Initiated, Override Thread QoS User Initiated
User Activity: 0 samples Idle, 1 samples Active
Power Source: 0 samples on Battery, 1 samples on AC
Binary Images:
0x10b6aa000 - 0x10b6b5fff com.hegenberg.BetterTouchToolAppleScriptRunner2 1.0 (1) <D6C6B032-ACD6-357A-B4A2-354BFB7A7939> /Users/USER/*/BetterTouchTool.app/Contents/XPCServices/BetterTouchToolAppleScriptRunner2.xpc/Contents/MacOS/BetterTouchToolAppleScriptRunner2
0x10dd54000 - 0x10dd83fff com.apple.osax.standardadditions 2.7 (401) <9596062F-AA1A-36AE-A416-03B1484934F5> /System/Library/ScriptingAdditions/StandardAdditions.osax/Contents/MacOS/StandardAdditions
0x7fff200b3000 - 0x7fff200e8fff libxpc.dylib (2038.40.38) <003A027D-9CE3-3794-A319-88495844662D> /usr/lib/system/libxpc.dylib
0x7fff201cd000 - 0x7fff20211fff libdispatch.dylib (1271.40.12) <CEF1460B-1362-381A-AE69-6BCE2D8C215B> /usr/lib/system/libdispatch.dylib
0x7fff20346000 - 0x7fff20374fff libsystem_kernel.dylib (7195.60.75) <4BD61365-29AF-3234-8002-D989D295FDBB> /usr/lib/system/libsystem_kernel.dylib
0x7fff20381000 - 0x7fff203bbfff libdyld.dylib (832.7.1) <2F8A14F5-7CB8-3EDD-85EA-7FA960BBC04E> /usr/lib/system/libdyld.dylib
0x7fff203f2000 - 0x7fff2088dfff com.apple.CoreFoundation 6.9 (1770.300) <EAC298C4-CE3E-3551-A832-42ED9A13EF74> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff2119f000 - 0x7fff21502fff com.apple.Foundation 6.9 (1770.300) <44A7115B-7FF0-3300-B61B-0FA71B63C715> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff24bee000 - 0x7fff24f53fff com.apple.SkyLight 1.600.0 (569.6) <35876384-45F9-3C62-995B-38EC31BE75D7> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff26240000 - 0x7fff262b5fff com.apple.AE 918.0.1 (918.0.1) <3A298716-A130-345E-B8FF-74194849015E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff286c5000 - 0x7fff289c4fff com.apple.HIToolbox 2.1.1 (1060.4) <93518490-429F-3E31-8344-15D479C2F4CE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff36430000 - 0x7fff3644bfff com.apple.openscripting 1.7 (190) <D0B98DF9-7A61-3810-AE81-2F870DCC2AC0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff6f769000 - 0x7fff6f79afff com.apple.OSAKit 1.5 (112) <68951244-CF62-3D3C-BC55-583A3B6A35A2> /System/Library/Frameworks/OSAKit.framework/Versions/A/OSAKit
0x7fff702f9000 - 0x7fff7037bfff com.apple.applescript 2.7 (401) <4F12DB4F-3915-3CBD-89FE-2841DFBD6E52> /System/Library/PrivateFrameworks/AppleScript.framework/Versions/A/AppleScript
