I have BTT processes in Activity Monitor that are from previously deleted menubar or notch bar links to websites. If I close BTT they disappear and return upon launching. I have reset BTT but when I import the configuration they return. They are nowhere to be seen in the configuration panel however, not as right click alternatives, and not under incorrect headings. The screenshots are from the activity monitor entry for app.simplenote.com, a previously deleted menubar item.
/System/Volumes/Preboot/Cryptexes/OS/System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
/System/Volumes/Preboot/Cryptexes/OS/System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
/Library/Preferences/Logging/.plist-cache.LWKPfKe0
/System/Library/CoreServices/SystemVersion.bundle/English.lproj/SystemVersion.strings
/usr/share/icu/icudt70l.dat
/private/var/db/timezone/tz/2022g.1.0/icutz/icutz44l.dat
/System/Volumes/Preboot/Cryptexes/OS/System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Resources/en.lproj/Localizable.strings
/System/Volumes/Preboot/Cryptexes/OS/System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Resources/en.lproj/Localizable.stringsdict
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/SystemAppearance.car
/private/var/folders/wp/xtx2msr94xb7s494chw3_9mw0000gn/0/com.apple.LaunchServices.dv/SystemDataOnly-com.apple.LaunchServices-4031-v2.csstore
/Users/user/Library/Caches/com.hegenberg.bettertouchtool-setapp/WebKit/NetworkCache/Version 16/Records/57C46F7A02B832B4699887129BE7E691D46E9234/Resource/F7FAA131AB13221ADABA4FE0C811228A502B3528-blob
/Users/user/Library/Caches/com.hegenberg.bettertouchtool-setapp/WebKit/NetworkCache/Version 16/Records/57C46F7A02B832B4699887129BE7E691D46E9234/Resource/3309B5875A45685DAE146C980AD8345EDD2CAF64-blob
/Users/user/Library/Caches/com.hegenberg.bettertouchtool-setapp/WebKit/NetworkCache/Version 16/Records/57C46F7A02B832B4699887129BE7E691D46E9234/Resource/7765DCF0D77F6DA092109527F9A323773EB8216F-blob
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/FauxVibrantLight.car
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/Common.loctable
/usr/lib/libobjc-trampolines.dylib
/System/Library/Fonts/Times.ttc
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/Aqua.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/VibrantLight.car
/Users/user/Library/Caches/com.hegenberg.bettertouchtool-setapp/WebKit/NetworkCache/Version 16/Records/57C46F7A02B832B4699887129BE7E691D46E9234/Resource/AAB0D2CE82253B991018E33D933764AD299A95A8-blob
/private/var/db/nsurlstoraged/dafsaData.bin
/System/Library/Fonts/Helvetica.ttc
/System/Library/Fonts/SFNS.ttf
/System/Library/Fonts/SFNSItalic.ttf
/System/Library/Fonts/Supplemental/Arial.ttf
/System/Library/Fonts/Supplemental/Arial Italic.ttf
/System/Library/Fonts/Supplemental/Arial Bold.ttf
/System/Library/Fonts/Supplemental/Arial Bold Italic.ttf
/System/Library/Extensions/AGXMetalG13X.bundle/Contents/Resources/ds.g13d
/dev/null
/dev/null
/dev/null
/System/Library/Frameworks/CoreImage.framework/Versions/A/Resources/ci_stdlib.metallib
/Users/user/Library/Preferences/.GlobalPreferences_m.plist
/System/Library/Frameworks/CoreImage.framework/Versions/A/Resources/ci_filters.metallib
/System/Library/Frameworks/CoreImage.framework/Versions/A/Resources/ci_stdlib_stitchable.metallib
/System/Library/Frameworks/CoreImage.framework/Versions/A/Resources/ci_filters_stitchable.metallib
- Type of Mac: Studio M1 Ultra
- macOS version: 13.1
- BetterTouchTool version: 3.962
