right mouse down
So i want my “right mouse hold down” on my keyboard. And when i release my keyboard key it also release the “right mouse down”
is there any possibility to do this ?
and if this is not possible can i put hold down and release on the same key?
im still new to btt :slight_smile:
thanks alot in advance
You can configure that using the predefined action "Custom Mouse Buttons & Modifiers"
create a second version of your shortcut that triggers on key up to release the click:
yeah i have that, i was just thinking if its possible to make it work on one button
What do you mean by one button? (You can use any key / shortcut, the shift+cmd+r is just an example.)
i mean press F “hold down right mouse” press f again “release”
yes the setup would look the same just with F instead of shift+cmd+r. However you would not be able to type F anymore if you configure it like that.
If you don't want to release on key-up you can use the "Cycle Through Multiple Actions" meta action.
I wouldn’t recommend this, but if I had to set it up, I’d do it like this:
"f" tapped briefly (down, up) → types "f"
"f" held down → triggers something else
"f" released after a “longer” time → resets everything
