Hello, just a question—why doesn’t this action work with a right‑click?
It does work with other buttons, such as Button 6.
Even though both actions fire, the one set for Long Hold Down and Drag Down are triggered.
I’ve highlighted the actions below.
Am I doing something wrong, or what?
@Andreas_Hegenberg Any support here?
I'm not 100% sure whether I understood the issue correctly, can you try whether it is solved with 6.276?
Yes, the double‑trigger issue is fixed, but one thing is still not working: the right click. Can't I adjust the "Right Click Drag Down (Discrete)" category to perform an action? It works with other buttons, but not with the right‑click button.
I added extra handling for right-click drag in 6.277 it should now work!
