Hello,
I'm testing BTT at home with an old Apple remote and it seems to work nicely...
However I'd like to have more buttons and I'd like to know if a RF remote is compatible with BTT ?
A remote like that for example :
https://www.amazon.com/Rii-Multifunctional-Wireless-Keyboard-Infrared/dp/B06XHF7DNQ
Would I be able to customize the buttons like I do with the Apple bluetooth remote ?
If no is there another remote model that works well with BTT ?
I need the classical "media" buttons (numbers, volume, play/pause,...)
If yes then I buy BTT right away
Thanks !
Matthieu
