Resize window to right third not working
Hi @Andreas_Hegenberg
I have this trigger which resizes window to the right third. It gets triggered and the window move to the right but only resizes to half. The window kinda flickers between 2/3 and 1/2 before setting back to 1/2. There is not other trigger. I actually moved from a old machine which had this working correectly to this new one. I exported/imported the same profile
Hey @andy4222 , I've just tried this and it is working on my end. What's your BTT version? Have you tried to recreate this trigger?
My BTT is Version: 5.199 (2025021219) on macOS 14.7.2 (23H311)
macOS 15.3.1
BTT 5.076
Is there a way to update to the new version and check? Also are you sure that the ESC is not modified in any way?
