Repeat Delay is constantly being reset to 0
Mac Mini 2019
Mojave 10.14.4
2.850
Mac Mini 2019
Mojave 10.14.4
2.850
Hey,
in which menu does this happen?
Hey,
Thanks for the reply. It's in the Trackpad Menu and only the new UI is effected. I have a little more clarity on what's happening now. When importing a preset the value for the repeat delay on ever action is being reset.
Im also noticing that typing in a number for repeat delay and Repeat Rate doesn't actually move the slider, so it's not actually doing anything.
Last thing is that even when I adjust the slider and set a value, I only get about 10 repeats and then it quits working entirely until I restart BTT.
Ah thanks for the details! Will be fixed in the next build!
Thank you!
