I just saw the new reminders widget function of the calendar widget!
Everything below talks about the "one-event" mode or current day for the widgets.
It seems alright, however it doesn't seem to match AQT's script-based widgets yet.
I can't assign actions to these on tap
Reminders widget only supports scanning for the current day, AQT's script based reminders widget scans the next week.
lowercase am/pm
text truncation
"No Reminders Due This Week" instead of "No More Events" or custom empty notice?
These would be so good to add to remove iCalBuddy dependancy!
Comparison:
Left is BTT, Right is script based. I made them the same as much as possible. Yes, the BTT reminders does have a reminders icon assigned but it isn't showing for some reason.
I'll add more options soon and for full customizability I'll add a scripting function to retrieve the events via Apple Script and then do whatever you want with them
AM/PM however is retrieved from your system preferences (Language & Region => Advanced):
Yup it seems like the date formatter ignores the user specified am/pm symbols for some reason. (Probably this setting is hidden so well in System Prefs that even Apple forgot about it :-P)) I'll report that to Apple and for now add an option to the region settings in BTT to override that.
