Note:
I am trying to set the screen brightness keys to change the screen brightness in small increments instead of the default behavior. I tried assigning the keys to the either the Brightness Down/Up (Small Step) shortcut, or the keyboard shortcut option+shift+Brightness up/down. The keys don’t respond and sometimes after a while, the accumulated keystrokes trigger the brightness to change.
MacBook Air M2 keyboard
- Type of Mac: MacBook Air M2
- macOS version: 13.6
- BetterTouchTool version: (please post the exact version - not just "the latest one") 4.272 42713
