Quotes around script output?
I don`t know it its a bug, but I have screen widgets to show battery and time on the desktop. Since the last Update 4.3740 I have now quotes around it.
The script is this:
set pctg to do shell script "pmset -g batt | awk -F '[[:blank:]]+|;' 'NR==2 { print $4 }'"
grafik
Is that purpose or do I have to change something? (not into scripting)
how are you calling the script within BTT?
Yes
can you check whether 4.375 fixes the issue for you?
Yes, works again!
